Diagnostic Code P061B & P2106???
Old Jun 12, 2009 | 08:33 AM
jma1558's Avatar
Default Diagnostic Code P061B & P2106???
Took car to Auto Zone and got two codes, P061B and P2106. The man didnt know what the codes meant. Can someone please explain what this means car has been acting up lately and it's driving me insane!!
Thanks in advance.
Old Aug 11, 2009 | 08:27 PM
jacque.lavalle's Avatar
Default The codes
Looks as though it maybe the throttle position sensor
Old Feb 28, 2010 | 10:23 PM
bradalee's Avatar
Default me too
i have the same codes in my f-150, ganna check it out next weekend. what fixed your problem?
Old Mar 1, 2010 | 07:16 PM
Default Codes don't tell you what is wrong
Okay... sorry for being gone so long. The problem was fixed once I convinced the dealer that pulling the heads was the wrong corrective action. They finally found a broken wire to the #4 injector, causing what the code says as a too lean of a mixture (ergo, why they thought it was a valve). Fixed wire, problem solved. Driven to Charleston and Boston with no repeat, no problems. Great little car, now!
Old Jun 6, 2010 | 06:06 PM
NTBD486's Avatar
I have an 06 Freestyle and I have both of those codes and my car accelerates by itself and then shuts off..it is crazy.
Old Jul 25, 2010 | 01:37 PM
starr2199j's Avatar
Default well???
My car jumped also then cut off. Autozone said codes P061B and P2106. Has anyone found out the correct way to fix this problem. I have heard that it is the throttle body......
need help please.....
Old Sep 23, 2010 | 07:12 PM
cbyers's Avatar
Unhappy p061b
Does anyone know what this code means? My 07 Freestyle engine will rev without pushing the gas and the cut off.
Old Sep 24, 2010 | 06:50 AM
NTBD486's Avatar
Yes...your throttle body needs to be cleaned out..it is very simple and only takes a few minutes...my car has done the same thing..I have an 06 Freestyle with 95000 miles on it...You do have to continue to clean it out every so often though but it saves you ALOT of money at the dealership. GOOD LUCK!!
mbozant
Jun 27, 2014 10:08 AM
Boilerbob30
Feb 11, 2013 09:07 PM
steve69
Feb 16, 2012 12:29 PM
bigcee50
Oct 8, 2010 11:06 PM
konin1973
Sep 25, 2009 11:47 AM
