2008 ford edge trans problems
Old Nov 26, 2009 | 02:32 PM
02sd's Avatar
Default 2008 ford edge trans problems
when the truck warms up and sitting at a light, When the light goes green and you try to give the edge some gas it slams into a gear, feeling like we have just been rear-ended! making some odd noise also
The ford trans tech said if there is no light/codes there is no problem
But obviously there is a problem
and Ideas what it is?
Old Nov 26, 2009 | 02:34 PM
02sd's Avatar
Default problem with trans
I just took it for another ride, up a hill and stoped it feels like its maybe in reverse and fwd. as it will not roll back or go forward until you rev the engine to about 2000 rpm and it gives a hard bang and goes into your fwd gear again.
A quick stop does not do this it will act normal.
Old Jan 13, 2010 | 07:56 AM
Still under warranty? I would take the Service Manager on a ride and have him/her experience what you're talking about and experiencing. Sometime, this is the only way to get them to listen. If they want a mechanic to do the ride, make sure that it's the mechanic that will be working the issue.
Last edited by Use Common Sense; Jan 13, 2010 at 07:56 AM. Reason: Keyboard doesn't know how to spell...
Old Jan 13, 2010 | 10:54 AM
digital_diversion's Avatar
start with the basics...
did you check fluid level? sounds like the tranny is low on fluid...
when you have to rev motor you are raising fluid pressure inside tranny until it locks up the forward clutch packs to put you into gear...
if its full..you have a problem.....
Old Jan 14, 2010 | 04:33 PM
02sd's Avatar
Default ecu
ended up being the trans ecu under the oil pan
Old Jan 18, 2010 | 02:18 PM
wrenchbender7's Avatar
I have a customer that has a 2000 Ford Excursion 5.4. It has a tranny problem when you put it in reverse it works fine, but when you put it in drive it dies out every time. When I lift the rear tires off the ground I can get it to shift through the gears fine, but as soon as you stop the tires it dies out. I can even brake torque it to keep it running. I think that I have a problem with the torque converter lock up solenoid. Has anyone heard of this problem, and what are the possible fixes. No codes and tranny was rebuild recently. Please help!!!
Old Jan 21, 2010 | 12:06 PM
ralphie250's Avatar
if it has a 4r100 in it it can either be the solenoid body or the converter causing it to stall the vehicle. those solenoid bodies are bad about the weld cracking at the tcc solenoid. what else can you tell me?
Old Jan 22, 2010 | 05:08 PM
Default excursion tranny problem
I found the problem keep and eye out for these they are nightmares. I replaced the solenoid pack and still had the same problem. F**CK now that I'm 400$ in the hole I got frustrated looking for a shorted wire and traced it all the way back to the pcm. Yup it was a pcm shorted out no codes or nothing. So of anyone runs into this problem trace the wire back to the pcm and check that first. It might save you 400$ what a kick in the *****!!!!
Old Mar 3, 2010 | 07:16 AM
heerdez's Avatar
2008 should bring it in to warranty this is a seal problem
Hollie Fritz
Aug 8, 2017 05:55 PM
Sottyeh
Jun 27, 2015 06:51 PM
bmagerkorth
Feb 4, 2014 03:19 AM
flyboy073
Jan 12, 2013 10:42 PM
mav02155
Oct 9, 2009 11:34 AM
