Tune up
Old Jan 31, 2010 | 08:02 PM
mgar75's Avatar
Default Tune up
Hi I have 2005 freestar 4.2L
What is the easyest way to gain access to the rear plugs.
I don't see room under the van.
Old Feb 1, 2010 | 06:34 AM
There are two ways to do the rear plugs. I have done both. The easiest way is to remove the wiper arms, then the upper and lower cowling (Just a few bolts) and unplug the wiper motor. Then the plugs are exposed. Don't forget to reconnect the wiper motor when reinstalling the cowling. The hardest way is to get the front of the vehicle in the air. The left and middle plugs are accessable with a little contortioning by the steering rack. The right rear plug is accessable thru the right wheel well after removing the tire. Use dielectrical grease on the plug ends/wire boots and some copper antisieze on the plug threads.
Old Feb 1, 2010 | 07:16 PM
mgar75's Avatar
thank you for the help
Old Feb 2, 2010 | 06:42 AM
No problem. Another thing I would do is run Iridium spark plugs. They withstand their enviroment better than platimun spark plugs. Also with a thinner center electrode they require less voltage to jump the gap under compression, thus reducing the electrical load on the ignition system. I will be replacing my plugs, wires and coil this spring on my Freestar.
hydrashocker
Nov 15, 2009 02:53 PM
unclelakeman
Jan 16, 2009 11:47 PM
7LitreKen
Jun 2, 2007 07:28 AM
booknee
Jul 12, 2006 01:15 PM
johnboy
Jul 12, 2005 05:23 PM
