Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and let's talk about it.
? involing Lower Contol Arm/Ball Joint
Old Feb 2, 2010 | 10:59 PM
cobra--x's Avatar
Default ? involing Lower Contol Arm/Ball Joint
Hi, I have a 1994 Mercury Cougar. I was told that the upper ball joints/control arms were bad along with the outer and inner tie rods (by three different mechanics) So I replaced all of these parts on both sides of the car. I just took the car to get it aligned and I was told that they can't do it because the lower ball joints/contol arms are slightly loose (the control arm has about a 3/4" play in it) Anyway, the car drives perfectly straight with no shimmy if I keep it at 55-65 mph, but if I go at a faster speed (80+) the car starts to shimmy really bad from the lower arm. I was wondering how safe this is to drive. I spent a lot of money on those other front end parts and don't really have enough for the lower arms/ball joints yet. I was wondering if I'd be able to drive this car for about a month or if I should just put it away and give up on it for a little while, til I get the money (the latter isn't really convenient as I work twenty miles away and would have to find an alternate means of transportation)
Cobra X
Old Feb 21, 2010 | 06:40 PM
Unioxia09's Avatar
Default involing Lower Contol Arm/Ball Joint
It comes tomorrow and I am hoping to install it saturday morning. I got the Lower control arm w/ new outter and inner ball joints already pressed in. I am only doing the drivers side right now. I just dont have any tools or anything because they are all in the back of our storage container. Who would like to help? I figure it take 1-2 hours max
primem
Feb 12, 2012 09:17 AM
JoeKovacs
May 29, 2011 10:01 AM
JoeKovacs
May 13, 2011 04:45 PM
hockey_head
May 13, 2008 10:19 AM
frankd
Mar 21, 2008 01:03 PM
