Ranger starts with a push but not with the key
Old Jan 1, 2007 | 03:23 PM
sludgemonger's Avatar
Default Ranger starts with a push but not with the key
This is a 1993 Ford Ranger and for some reason it will start readily if it's push started however when you try to start it using the key the engine just cranks and cranks. Anyone out there have any ideas? I don't mind parking on a hill but snow is comming!
Old Jan 1, 2007 | 11:23 PM
wheelsup68's Avatar
Default RE: Ranger starts with a push but not with the key
Almost got to be a problem with your ignition switch, but a little concerning why you can turn to run position and get engine to run on push start. I would still think ignition swich.
Old Apr 24, 2007 | 09:02 PM
Num25Duke's Avatar
check out your battery cables. i had the exact same problem and what it was was that mycables had internally corroded and the starter couldnt pull enough juice to start the engine.
Old Jan 7, 2011 | 01:03 AM
haroldmartin's Avatar
Wink ranger head ach
i had the same problem. it drove me crazy. go to advance auto
it is the ing. switch in the collum.it is a 10.00dollar part. takes
about 10 min. to install. not the key switch but the ing.
switch. it is a slide switch.drop the bottom cover of the collum
unplug the wiring harness. take screws out install new one
Old Jan 12, 2011 | 10:42 PM
Talking
if you want to test my answer to your problem turn
your switch to on take a screwdriver and jump your silenoid
across . the small wire to the starter wire . if the collum
switch is bad it will start.thats how i started mine for a
while till i git the switch back.
let me know how it goes.that screwdriver will save a lot
of pushing
elojs
Jun 18, 2012 05:34 PM
308man
Mar 19, 2012 01:26 AM
snapper1d
Dec 10, 2010 09:26 AM
streetglide007
Apr 11, 2010 12:23 PM
Lennygrt
Apr 30, 2006 08:55 PM
