Shocks or Load Level Suspension problem
Old Sep 28, 2008 | 01:44 PM
  #11
dannydoo's Avatar
Default RE: Shocks or Load Level Suspension problem
My compressor wont come one,anyone know where the relays are? 1998 expedition
the fuse gives power for 1 second then shuts off
Old Mar 29, 2015 | 10:59 AM
  #12
Brandi Studeny's Avatar
Having problems with my 04 expedition suspension raised high in rear and will not go down rides and drives rough what are my options?
Old Apr 1, 2015 | 02:12 PM
  #13
A lot of air suspensions utilize a leveling valve that when the height is correct it will neither add air nor exhaust air. If the arm to the valve is off or the valve is faulty , it doesn't know to lower the air pressure and will maintain what appears to be the correct height.
Old Dec 3, 2015 | 10:42 PM
  #14
Adam Lane's Avatar
I had that problem with my '05 Navigator. Took it to Goodyear to have them fix it. The air pump(they gave it a different name...but to me its just an air pump) went out. According them, if you have air bag suspension then you expect to be paying 400-500 bucks no matter what the issue is. Luckily I had a deal with the dealership where I only pay $200 no matter how much any repair costs. But it took them about a week to fix the air pump and after that it worked just fine. Not saying that's what you're issue is...it could be one of many things. From a leak to a bad pump. I know I could hear the air escaping as the pump would try to fill the air bags...but the Navigator just would not lift. It looked like I was driving a lowrider. But a lot of places will at least take a look and let you know whats wrong for free.
young ford
Sep 28, 2010 02:04 PM
jdmak68
Jul 16, 2007 07:16 AM
wildcat_1
Mar 10, 2007 06:40 PM
MRLEXPY
Dec 10, 2006 11:44 AM
mustangsidewinder
Jan 23, 2006 03:37 PM
