Stalls in Drive (1998 Explorer Sport SOHC)
Old Mar 14, 2010 | 04:16 PM
  #11
streetglide007's Avatar
Default stall
I've got an 02 ranger 4.0 sohc that has a stalling problem with no codes. I have replaced the IAC and the TPS cleaned the MAF an the throttle body and searched for vacuum leaks, Ford said the computer needed to be updated so I had them do it, no luck still stalls. when ice cold the truck will start and run fine, after it worms up it starts to stall also stalls wile driving shudders, jumping gears. This is driving me crazy so any help would be great.
Old Mar 19, 2010 | 12:23 PM
  #12
Green Lantern's Avatar
Default 02 Rnager stall
If the engine is cold and you start it up and just sit there in park till the engine warms up all accessories off such as AC, heater, lights... does it stall in park when warm? If not does it stall with all accessories off in drive or any other gear, not moving not touching throttle just putting it in gear?
When you cleaned the throttle body, did you remove it and clean the back and front of the butterfly valve and housing? It does not take much build up to cause this problem.
GL
Old Mar 20, 2010 | 07:41 AM
  #13
yes the throttle body was removed and cleaned it had stalled under all conditions. but I have an update. I got sick of searching took it to the dealer and they had to replace the ecu. it's been a week no problems so far. knock on wood.
Thank you for your reply
raleighnccrownvic
Jan 10, 2012 08:18 PM
EStein9077
Oct 4, 2010 03:56 PM
M.Brower
Jan 30, 2010 01:09 AM
CoreyTrevor
Oct 27, 2009 12:54 PM
SportTrac03
Jul 23, 2009 05:11 AM
