96 Ford Taurus G L Fuel Pump
Old Mar 12, 2009 | 08:03 PM
  #11
tobacmon's Avatar
Thanks again for your help--It was the pump and now the ford is back on the road---It's always nice to have a lift (friend has residential garage w (2) lifts ) and was a quick fix. I did notice the splice made in the line going to the connector. I heard someone post here that this would also cause failure and tpo make sure the splice was good--it was-----Pretty nice of Ford to put a splice before the pump connector--Go figure.
There is one more problem and hope I'm not being a pain---My Air Bag light inside / dash is flashing the code 5 & 1 =51.---From what I understand this is a fuse link---Is this true and if so where is it located. My buddy told me he thinks it's in a module over the steering column in a black box.(Air Bag module) Does this mean I have to replace the whole module or is it just a fuse---Please explain if you know what I'm talking about..Again thanks!!!
Old Mar 12, 2009 | 11:06 PM
  #12
The air bag diagnostic monitor (module) is behind the radio/integrated control panel.. If your getting a LFC 51 then the 'internal' fuse inside the monitor is blown.. It's not a servicable fuse and the monitor will need to be replaced.. 'BUT', plugging in a new diagnostic monitor if any of the system components are shorted to ground, harness issues, or the bags have/had been deployed prior (?) with only some of the parts replaced can possibly take out the fuse again.. Code 51 means that the system was shorted intermittent/temp, and LFC 13 flashed would be for a continuing short to ground as a higher priority code..
Old Mar 14, 2009 | 05:39 AM
  #13
tobacmon's Avatar
Thanks again for responding---What is the proper step by step procedure I should take to remedy this error? Can pull the radio to access the Module? I am sure you will know what to do---LOL Will a diagnostic PC tell me where to start? Or is there an easier method--anything to save $$$--Thanks!
Old Aug 30, 2009 | 06:00 AM
  #14
tobacmon's Avatar
This was a Bad Fuel Pump--replaced and working great---Thx. Hayapower!
Old May 3, 2011 | 12:42 PM
  #15
robdaddio69's Avatar
Default 96 taurus
my car will start then cuts right off....checked filter it was fine......while i had filter off i turn key the pump kicks on for a sec shoots gas out then cuts right off....is the pump definately my problem?pump is $123.00 n is a good little job to replace.......please help
jozepy24
Jul 13, 2019 05:21 AM
fordexpedition2006
Apr 21, 2017 05:23 PM
Spaznaut
May 24, 2014 02:10 PM
robbyradio
Jun 17, 2013 04:10 PM
grumpydave
Jan 18, 2008 03:15 PM
