removing cats
Old May 4, 2009 | 05:34 PM
  #11
JTGrant1's Avatar
No it isnt against the law to put a high flow cat, or cherry bombs, or anything like that on! It is "technically" illeagal to take out your cats if the vehicle came stock with them though. I dont have any on my truck. You can hollow them out, ant weld in pipes so it just looks like they are there though... What they don't know (cant see), wont hurt 'em!!! I also put ford racing shorty headers on my truck. I drag race with it.
Old May 5, 2009 | 02:24 PM
  #12
Bullitt94's Avatar
No, changing the exhaust or putting in new/different cats is not illegal. Removing the cats is; that is what I meant.
Old May 5, 2009 | 08:23 PM
  #13
JTGrant1's Avatar
well... its technically illegal to remove your cats if they came stock on your vehicle. But if your state doesnt inspect for emissions like mine does (Massachusetts), than you should be ok if the cops arn't a$$es. Anouther way to get around this problem is to punch out (hollow) the cat and incert a piece of pipe so it will look fine if they visually inspect it, but will not restrict flow, and still sound cool! good luck.
Old May 6, 2009 | 08:20 AM
  #14
Bullitt94's Avatar
That is true as well. If you don't make the exhaust too loud the fuzz doesn't seem to care all that much. If you are too loud and give them a reason to pull you over, then you may be in a bit of hot water. They would most likely give you one of those warnings that require proof of repair or you get a fine.
Old May 7, 2009 | 02:35 PM
  #15
oldtimer35's Avatar
Then there is the visual test, not a sniffer test at the tailpipe, but just a look under the vehicle to make sure that everything is in place. That's what they do here in Texas, in the counties that don't have the sniffer test.
Old May 12, 2009 | 10:34 PM
  #16
greuelc's Avatar
ok its sound like high flow cats would be best. What brand should i go with that will give me a cat-less sound and still have back pressure on the motor.
willy j
Sep 13, 2014 01:53 PM
04ebexp
Dec 24, 2007 08:17 AM
04ebexp
Dec 12, 2007 01:27 PM
01ranger
Oct 8, 2007 04:02 PM
drw0392
Apr 25, 2006 03:52 PM
