beeping from under dash
Old May 31, 2008 | 11:37 PM
  #11
Default RE: beeping from under dash
Restraints Control Module....
Old Feb 14, 2009 | 07:12 PM
  #12
kirkmccartney's Avatar
Just bought a 97 F-150 Extended cab and it has the beeps also.
Old Feb 14, 2009 | 07:13 PM
  #13
y 97 F-150 has the beeps also
Old Feb 18, 2009 | 04:04 PM
  #14
bgrishaber's Avatar
My 02 Escape (155,000 mi) has just started beeping after the dash bulbs were replaced. (didn't help the display)
5 beeps, times 4 at first. Now its 5 times.
Old Feb 19, 2009 | 01:25 PM
  #15
Air bag light illuminate or flash?
If the lamp doesn't function, and the system detects a fault somewhere in the SRS, the restraints control module will signal the cluster to chime 5 times.. S/B 5 sets of five tones.. If your getting the audible tones and no lamp function the DTC's (trouble codes) need to be retrieved from the control module through the vehicle diagnostic connector with a scan tool. For SRS issues with a functioning indicator lamp, you can count the lamp flashes or LFC's for a trouble code and direction to go..
Old Feb 20, 2009 | 02:18 PM
  #16
bgrishaber's Avatar
The air bag light used to flash until my latest service where they replaced the dash bulbs. Now the light is off and it beeps. Thanks alot. I'll post when its fixed.
Old Jul 17, 2010 | 07:54 PM
  #17
Escape04's Avatar
Default Beeping.....
I just bought a 2004 Escape and it, too, has the beeping sound problem -- 5 beeps, 5 times, then about half an hour later these repeat. Has anyone found out the problem and the needed solution yet?
Old Jul 26, 2010 | 06:25 AM
  #18
Minnylolly's Avatar
When I read your entire comments then I really impress with your site.
Old Oct 12, 2010 | 06:00 PM
  #19
bfossa's Avatar
My 2002 beeps six time, no clue?
Old Oct 12, 2010 | 06:16 PM
  #20
bfossa's Avatar
Default I agree this beeping is annoying
My 2002 beeps six time when I turn off the ignition, no clue.
