Need HELP ASAP with starter cylinder for Ranger
Old Dec 19, 2006 | 09:33 PM
  #11
Silverrr's Avatar
Default RE: Need HELP ASAP with starter cylinder for Ranger
Thank you for all the info , just pick up the part and this is what they sold me ...a igniton cilinder with a set of keys ...so it will be a direct swap from the OEM cilinder ...only problem my OEM key comes with a chip in it ..will the truck start if I swap the cilinders ??? Im starting to think that it won't ....if this is the case I will need a rebuild set from Ford so it can work with my OEM key and chip[:@].
Old Dec 19, 2006 | 10:29 PM
  #12
Silverrr's Avatar
I got the old cilinder out ...the piece that broke is the tip of the cilinder it self ...the part that Autozone sold me is close but not the same ,tomorrow I will go to the Ford dealer and see if they have that tip or I guess I will have to buy the rebuild kit , I will like to just replace the tip only on the old cilinder so I don't have to mess with re setting the chip in the key (transponder key is the name I found out) ....one more thing... is it possible to disassemble the original cilinder ???? I didn't see a way to do it ...Thankss!![sm=smiley20.gif]
casey1985
Dec 25, 2009 10:06 PM
RS-ROSS
Oct 31, 2009 02:42 PM
jazzy02
Dec 30, 2008 01:43 AM
KINGDELL
Apr 13, 2008 10:01 AM
SuperFord73
Apr 26, 2007 07:59 PM
