Check engine Light
Old Jan 12, 2007 | 12:27 AM
  #11
jim70's Avatar
Default RE: Check engine Light
I went for a junkyard hunt and pulled a complete switch assembly from a 1997.It looked in rough shape compared to mine.I've installed it and thus far after about 40 miles of driving,the light has stayed out.
Cross my fingers and will give it tomorrow before I take it in for a smog check.
To be continued...
Old Jan 12, 2007 | 03:55 PM
  #12
jim70's Avatar
Damn....Check Enf light back on and again P0470!!!
What next??
Old Mar 22, 2011 | 03:47 PM
  #13
Dashobie's Avatar
Default 1997 Ford Aspire P0470 code
I have a 1997 Aspire that had a check engine light and a P0470 error code,it's a misleading code i removed the EGR started the car the exhaust port was fine the intake port barely had any suction.I used and old trick when the engine is hot brought the RPM up to about 1500 then from a spray bottle sprayed water into the port to causing stream to clean it,once done i could feel hard suction i also replaced the EGR not sure i had to but the car has 88000 miles on it,but the light was still on so i disconnected the battery all night to make sure the computer was totally clear.Then in the morning i started the car let it warm up without touching the gas pedal drove it for about 40 miles then took it out on the highway for 5 miles at 55 mph let it coast to 20 then slowly up to 60 mph for 5 miles then coasted to 20 then fast up to 65 mph for a short distance a highway cycle no check engine light still so i drove right then to the emission test center the car passed all tests.
Before i did this i took it to a mechanic that bragged about his $10,000 machine had the car for a week,he said he couldn't figure it out and you can't get the EGR solenoid for that car anymore well that wasn't it.
But a huge help was the service manager at Roesch ford in Elmhurst IL.I'm not being payed by them they helped me for free i guess they figure do like they used to do in the old days help someone and you get payed back with word of mouth.
93redxlt
Mar 18, 2010 04:44 PM
allensimpson
Jan 10, 2008 09:40 PM
farris1307
Sep 9, 2005 04:59 PM
basketbjones
Aug 30, 2005 10:16 AM
bluemq1
May 16, 2005 08:06 PM
