98 escort 2.0 no fuel
Old Apr 2, 2007 | 08:10 PM
  #11
Default RE: 98 escort 2.0 no fuel
By the way shouldn't there be 12 volts coming out of the inertia switch to the pump?
Old Apr 2, 2007 | 09:58 PM
  #12
wheelsup68's Avatar
Your fuel pump always has 12 volts when the key is on. There is no pressure change thru the voltage suplied to the pump, it is controlled thru the fuel pressure regulator. As stated above the only down fall is not having a fuel cutoff in case of accident which none of the other big threee have anyway. Your fuel output is controlled thru drivers in the ECM, if I were you I'd be looking closer at that.
Old Apr 4, 2007 | 02:05 AM
  #13
That's the other type - I omitted - a system that always pumps to full pressure and uses the regulator seperately. Actually it's probably more common than one electrically regulated.
90EscortSTH
Mar 27, 2011 10:27 PM
jbrink
Apr 20, 2007 10:14 AM
jbrink
Apr 12, 2007 06:47 PM
jcbassmaster
Dec 22, 2006 04:42 PM
larry220
Jan 12, 2005 03:55 PM
