oil gauge
Old Oct 14, 2007 | 10:06 AM
seno71's Avatar
Default oil gauge
I have 2000 expedition and the oil gauge onley works 1/2 the time but I know that the truck has oil pressure could this be bad gauge or the sending unit
Old Oct 14, 2007 | 01:45 PM
Default RE: oil gauge
Hopefully just a bad sender..The sender is nothing more that an 'on/off' switch, meaning withoil pressure the senders switch 'closes' registering a normal pressure on the gauge.. You can try gounding the sender wire WH/RD and the gauge should read a normal pressure....
Old Jun 8, 2009 | 12:53 AM
Bigspark's Avatar
2000 Expedition: Had the same problem with the oil pressure sender, usually when cold. I replaced the sender to fix the problem. The sender is near the oil filter, next to the power steering pump on the 4.6 Liter engine. Easily assessable from under the vehicle. Mileage before failure: 110,000.
jcasaccio
Oct 7, 2018 08:02 AM
mikebrathole
Apr 4, 2006 12:40 AM
mikebrathole
Mar 2, 2006 01:25 PM
ashclan
Oct 19, 2005 04:40 AM
