Loud Noise Coming From Rear
Old Oct 17, 2007 | 01:46 PM
dbroncosfan22's Avatar
Default Loud Noise Coming From Rear
I have a 2006 Ford Five Hundred SE and when I am driving it, it makes this noise almost like it's coming from the mufflers or tires. If anyone has a solution or the same problem, please help.
Old Oct 17, 2007 | 02:01 PM
Default RE: Loud Noise Coming From Rear
Noises are the hardest to diagnose at the forum level.. Can you describe the noise, or if there is any other sensation/vibration, thump, rumble,ect along with the noise?
Old Oct 17, 2007 | 07:37 PM
The noise coming from my 06 Five-hundred is like awhistle noisetogether with a vibration. It sounds as if I need to have my wheel bearing change or something. it goes away sometimes and also gets louder at times. By the way thanks for getting back at me on the this problem,
Old Dec 29, 2008 | 10:52 PM
sonny32's Avatar
Mine just started today,,, and yes at a medum to high (55) speed it sounds like a rear bearing but if realy listened to at low speed it is comming from the front to mid section it is a ROAR sound as the car speeds up the roar get faster and as it slows, it slows,,(it almost sounds like the normal noise the car makes but allot louder)thats why I say it sounds like rear bearing but it is comming from the front,,, I thought it may be the CVT but someone (mullethead) said there were no gears in the CVT,,,or may be the CV joint,,, I dont know,,,, I cant workon anything past a 1985 model... Nowarning light on dash,,, Anyone have any Ideas???
It's a 2006 with almost 50,000,,awd,,,cvt besides that I like it,,,
Old Dec 31, 2008 | 01:57 PM
sonny32's Avatar
UPDATE,,, I took mine to the shop and they said it is the front wheel Bearing,,It's cover so I can rest easy it won't cost but the 25 bucks co pay,,
Hope this helps
Sonny32
fivevs
Apr 25, 2007 01:13 AM
jasonb
Mar 27, 2007 10:17 PM
bcrane3
Nov 12, 2006 09:06 PM
ranchoruiz
Aug 1, 2006 03:28 AM
fordexploder
May 19, 2006 09:05 PM
