Towing double
Old Oct 29, 2007 | 11:42 AM
TexasUltra's Avatar
Default Towing double
I'm going to be towing my travel trailer and a small utility trailer at the same time. It's legal in Texas as long as I am within the 65ft. limit. My tow vehicle is a 2002 Excursion 7.3l PowerStroke with the factory tow package. My question is...What is the best way to wire lights to the 2nd trailer?
I have the standard 7-pin plug on the TT, and my idea was to pull new wire under the TT for the Utility trailer and use the 4-pin flat plug at the same time. (TT plugged into 7-pin and UT plugged into the 4-pin.)
Has this ever been done? If not what was your solution?
CoyoteRoede
Feb 12, 2021 08:18 PM
Huk
Mar 1, 2012 07:55 AM
mrmet00
Jan 4, 2009 02:40 AM
TexasUltra
Nov 5, 2007 10:21 AM
Buckeye1872
Mar 4, 2006 02:42 AM
