aod trans. application
Old Jun 9, 2005 | 05:03 PM
65chero's Avatar
Default aod trans. application
Can someone give me advice as to what model aod trans. would be good to put behind a 280 hp. 302? I have this ina 65 ranchero and have an 8" rear end, with 355 gears.
Old Jun 9, 2005 | 11:21 PM
truckpuller's Avatar
Default RE: aod trans. application
The 351 and the 302 sport the same bell housing so any AOD perferably out of like a LTD or big Merc or something like that. There will need to be driveshaft modifications shift linkages to figure out and so forth. An AOD with 3:55 gears would be a great combo had a full sized conversion van with that combo and got 18 miles per gallon for gas mileage and it would get up and go also.
Old Jun 9, 2005 | 11:29 PM
65chero's Avatar
Thanks for the reply. Sounds like a good combo. Guess I'll hunting for a trans.
Old Oct 4, 2005 | 10:32 PM
68falcon's Avatar
I have an AOD behind a 351w with an 8" 3:55 rear in my Falcon. The AOD had some problems early on and Ford improved it along the way so the best ones are the newest ones. 92 or 93 was the last one made. The strongest ones were in trucks/vans. Next strongest were v8 Mustangs and SC? T-birds. PM me when you get to setting up the TV shift, I've done a couple of them. It's not hard once you get the right advice and setting it wrong can fry your tranny quick.
Old Oct 8, 2006 | 01:32 AM
roy's Avatar
roy
89 & up have stronger parts
go to lentechautomatics for all things AOD
or baumann `has a` good site too.
you wil not be happy unless you get a valve body which willl give you control over 1,2,3 shifts
lentech has a great one, you control all shifts & gives you switch to control overdrive
03usmc41
Dec 25, 2020 03:28 PM
bradkorn
Oct 18, 2011 03:28 PM
blondiez24
Dec 19, 2008 01:03 AM
jz57_cn
Mar 17, 2007 05:05 AM
jz57_cn
Mar 16, 2007 08:27 PM
