1998 ford contour...need help
Old Nov 27, 2007 | 09:21 AM
pokey2001ca's Avatar
Default 1998 ford contour...need help
About once a week I would get only cold air coming out of the heater and the temp gauge would go to overheat but then it kicks in and I get warm heat and the gauge goes back to normal so I thought it was the thermastat sticking so I put a new one in but it didn't solve the problem. Have any ideas what it might be
Old Nov 27, 2007 | 01:42 PM
BRETM's Avatar
Default RE: 1998 ford contour...need help
What size engine? Could be water pump, heater core clogged, low on coolant?
Old Nov 27, 2007 | 04:31 PM
the size of the engine is 2.5 litre
Old Jul 23, 2009 | 10:36 PM
djshoff's Avatar
make sure you put the thermostat in correctly. have the EGR valve checked. check your water pump belt.
BigChevy80
Feb 11, 2012 05:09 PM
trivium nate
Dec 26, 2007 10:53 PM
jimmynelson
Dec 3, 2007 06:51 PM
jimmynelson
pokey2001ca
Nov 27, 2007 09:21 AM
