low oil pressure
Old Dec 3, 2007 | 04:46 PM
bmkeiffer's Avatar
Default low oil pressure
I have a 94 150 with the straight 6. Rebuilt the motor and now i have no oil pressure. Thought it was the sending unit replaced it still didn't change so i bought a mechanical gauge and it's only read bout 5-6 psi. already pulled the pump and checked it and ran with out the gauge hooked up and oil came out, put the gauge back on and still 5-6 psi. Is that spot where the sending unit goes even a pressure spot. any feedback would help out.
Old Feb 2, 2008 | 09:19 PM
sho_ted's Avatar
Default RE: low oil pressure
sounds like you left out a plug in a oil galley or a mis aligned bearing.
Old Apr 19, 2008 | 01:07 PM
Could also be a defective oil pump right out of the box. Look for the loose plug or a block fracture or oil pasage blockage and try pressure testing the pump before you put it in - then you can trace where the pressure is going (if the pump's OK). Never install an oil pump dry - it can burn up by priming it from dry at even low RPM.
lisademski
Nov 11, 2010 08:23 PM
fishfun83
Jan 4, 2010 09:55 PM
Southwind13
Mar 26, 2009 11:49 AM
mint
Jun 24, 2008 11:20 AM
whitneycox
May 4, 2007 08:24 PM
