Replace Serpentine Belt
Old Dec 14, 2007 | 06:28 AM
crimey617's Avatar
Default Replace Serpentine Belt
How do I replace the Serpentine Belt on my 2002 Ford Explorer V6?
Old Dec 14, 2007 | 12:06 PM
Default RE: Replace Serpentine Belt
Fairly simple job...
On the belt tensioner, out close to the belt pulley(black arrow) there is a square slot for a 3/8 drive.. Genrerally you can insert a ratchet (longer 'flex head' type work well), or short 3/8 breaker bar into the tensioner slot.. Rotate CCW to take the tension off the belt and slowly release the hold on the bar/ratchet.. Then just feed a new belt over the drive components as show below.. Your 'belt routing' will/should be shown on the underhood decal as well.. Once in place, then repeat the belt tensioner load.. You can buy a tensioner tool, but most times you can improvise with basic tooling....
[IMG]local://upfiles/6756/8567B88483844D6D866AB6C142806491.gif[/IMG]
searchlight4759
Jul 10, 2012 08:23 PM
Demps
Jun 15, 2009 11:19 AM
Demps
Jun 15, 2009 03:54 AM
scaaar
Sep 2, 2006 03:12 AM
Ritehsedad
May 14, 2005 11:28 AM
