Engine Clicking After High Acceleration
Old Dec 27, 2007 | 09:25 PM
mocha_chai61's Avatar
Default Engine Clicking After High Acceleration
My '91 Tempo's enginerecently started clicking while accelerating onto the freeway. I didn't hear it until I was slowed in traffic, but its definitely apparent. I pulled off, shut off the engine, made sure it wasthe CV's or anything, that its genuinely in the engine.
A while beforehand, and still to date, my oil light has been flickering with any pressure on the brakes. I'm leaking oil out of the head gasket but keep levels regular. Any help?
Old May 12, 2008 | 02:23 AM
Default RE: Engine Clicking After High Acceleration
If it's for sure the head gasket - replace it. If it's a valve cover/rocker arm cover gasket - seal it. If you ran it with a bad head gasket you could've gotten oil in the antifreeze and overheated the motor. Either way if you punished it with a bad head gasket and there's oil in the antifreeze look for a rebuilt motor or a nice used one from a salvage yard. With overheating the average person doesn't need the repair downtime or headaches the old engine would give you. If it's a low miles engine (under 100,000 miles) it might be worth the trouble, but when oil gets in antifreezeor ratherworse antifreeze gets in oil - the bearings get wiped out under acceleration because antifreeze won't lubricate them as well at all. Water (antifreeze) falls from the bearing and doesn't lubricate as well - oil creates a thin layer that withstands engine firing pressure.
makuloco2000
Jul 2, 2014 10:31 PM
surferjoegomango57
Dec 11, 2013 02:32 PM
hiteshgswan
Apr 15, 2011 05:47 PM
ajhamel
Apr 25, 2008 11:50 AM
dae06
Oct 26, 2006 09:40 PM
