Ford Freestyle The new crossover, combining the versatility of an SUV with the compact size and feel of a station wagon.
horn not working
Old Dec 31, 2007 | 07:19 PM
jbelgodere's Avatar
Default horn not working
hello,
I bought a used 2005 Freestyle ad the horn stoped working. I dont have the owners manual and i would like to know where is the horn relay or fuse on the vehicle.
thanks
happy new year
Old Aug 16, 2008 | 11:28 AM
andry's Avatar
Default RE: horn not working
i think, there is nobody know. i'm sorry i'm not familiar with this car but make sure that the horn is good. if not maybe this is the horn problem. you only need replace with new horn.
Old Aug 19, 2008 | 08:03 PM
PhotoMaster's Avatar
I have the 2006 Freestyle. I will look at my owners manual for the location of the horn relay, fuses and fuseable link. The horns are easily visable looking into the grill on mine. There are two horns, so I don't think it's the horn itself, but anything is possible. You can hook a test light up to the horn connection and the other side of the light to ground, press the horn. If it lights, the horns are bad. If not, it could be a fuse or relay. The only other thing, and I had it on two Escorts, was the horn switch in the steering wheel. If that's the case, have a mechanic hook up a separate button. Otherwise they have to open the steering wheel, which is mega expensive, because of the airbag. I wouldn't play with the horn wires myself, because even using a tester on the air bag wires can set off the airbag and they often run in the same bundle. One mistake and then you have a hugely expensive repair.
Greg
stryperx6
Jul 28, 2010 07:58 PM
Bob Berumen
May 22, 2010 12:13 PM
peterson89
Feb 17, 2010 03:30 PM
jesus7
Apr 5, 2008 10:01 PM
purplepeople
May 4, 2006 04:41 PM
