#1 cylinder misfiring
Old Jun 20, 2005 | 06:34 PM
dbone420's Avatar
Default #1 cylinder misfiring
My '01 ranger suddenly started running rough. I figured It was misfiring so I took it to the auto parts store. They did a diagnostic and it said that #1 was misfiring. I bought plugs and will replace all of them tonight. Does that seem like the problem? I am hoping someone has had similar circumstances
Old Jun 21, 2005 | 11:28 AM
dbone420's Avatar
Default RE: #1 cylinder misfiring
I changed out the spark plugs and it did not fix it. I changed the wire for the #1 cylinder and still no change. Any suggestions??
Old Jun 21, 2005 | 05:06 PM
are you getting spark at the plug? check the injector signal with a noid light.
Old Jun 21, 2005 | 05:44 PM
dbone420's Avatar
Thanks I will check the spark. I have never heard of a noid light. can you get them at most auto parts stores?
Old Jun 22, 2005 | 03:11 PM
dbone420's Avatar
The plug is getting spark. Does that make it an injector problem?
Old Jun 22, 2005 | 06:24 PM
Yea it might be the injector, open wire, or even the ECM. The noid light is just a test light for checking the injector signal.
http://www.toolsource.com/ost/produc...W7U90E50490B66
Old Jun 22, 2005 | 06:30 PM
dbone420's Avatar
I will try that out. If the light is off would that be the wiring most likely? The vehicle has 65k so it is probably not the injectors I hope. Thanks for your help cctxfish!!!!!
Old Jun 23, 2005 | 05:17 PM
probably ECM, my guess, you can tie it into another injector signal
Old Jun 24, 2005 | 12:52 PM
dbone420's Avatar
It was the ecm!!!! They called it the ignition coil but I think it is the same thing. None of the auto parts stores in town had the part so I had to pay the dealer $120 for the part. ouch!! But it was fixed a lot cheaper than having it serviced. Thanks for your help cctxfish.
fireguyl11
Sep 9, 2006 06:02 PM
Bullitt94
Mar 15, 2006 11:08 AM
alex29573
Jan 8, 2006 01:09 AM
SKHAIRCORP
Aug 8, 2005 06:06 PM
SKHAIRCORP
