2001 V-10 location of the IAT
Old Feb 2, 2008 | 02:19 PM
DONTHETOOLMAN's Avatar
Default 2001 V-10 location of the IAT
I'm looking for the location of the IAT plug. Ibought a "wonder Chip" all it is is a risistor that bypasses the IAT I'll try it anyway suppose to increase fuel milage and power??
Old Feb 3, 2008 | 01:11 PM
2002BLGT's Avatar
Default RE: 2001 V-10 location of the IAT
do not put that POS chip in for the IAT , it will jack like 30 degrees timing in your truck which will make it ping like crazy , if you want to add power , get an aftermarket tuner for it , Sniper Special Forces will work on that truck , and then you can add timing and change the fuel curves for more power , without messing something up , and by the way if its its got 6 wires going to the mass air meter then the IAT is intergrated into the MAF ....
Old Feb 6, 2008 | 09:07 AM
davesbigford's Avatar
ORIGINAL: 2002BLGT
thanks for the intel
festy90
May 29, 2009 09:23 AM
u009374
Mar 29, 2009 07:27 PM
jvelliquette
Sep 13, 2008 04:45 AM
imagomer
Sep 12, 2008 09:15 PM
markymich
Jul 29, 2005 12:47 PM
