Go Back   Ford Forum - Enthusiast Forums for Ford Owners > Ford Trucks, Ford Vans & Ford SUV's > Ford Freestar
Welcome to Ford Forum!
Welcome to Ford Forum,
  #11
Old 07-05-2008, 09:01 PM
TheRealMrEd TheRealMrEd is offline
Default RE: 2004 Freestar rear lift gate handle
This happened to me moments ago on my 2007 Freestar. Outer liftgate handle came off and liftgate would not open. User's manual said to remove small square cover inside liftgate over latch and push little rod to the right (Left if you have power lift gate I have power locks, manual liftgate.). What they didn't say was which little rod. The trick is that the first little rod you find that looks like it has been diconnected from a pushrod does nothing!
You can try feeling (looking with flashlight) for a steel cable wire (NOT electrical wire) and tug on it with your fingers to unlock the latch. If that fails you gotta find the little NYLON rod to the right rear of the cable latch tower just referenced a little sort of bent white nylon rod that has a sort of hole molded into the top side that also looks like it should be connected to a pushrod but isn't. Push the nylon rod to the right and that should unlock the door. Once the door is opened (maybe even before not sure) remove the trim. This is only two phillips screms on the trim panel and two 8mm hex screws on the inner grab handle. Remove these and pull toward you at the bottom ( couple of places on sides where trim panel snaps into body pull free with fingers). Shop manual says undo trim around window first, but I didn't; just use care reassembling and start the 8mm screws BEFORE the phillips screws when going back.
When trim panel is out of the way, you'll eventually find the bar that slid over to disengage the handle hooks, push it to the side and reinstall the old handle. Voila!
Took about ten minutes, and I'm old!
  #12
Old 07-07-2008, 11:19 AM
SAFordOwner SAFordOwner is offline
Ditto! No longer covered under my factory warranty. Not covered under my extended warranty and the dealer quoted $300 to fix. Can you please send any docs, schematics, advice to: rob_mabry@yahoo.com?
Thanks for the assistance.
  #13
Old 08-15-2008, 02:10 PM
hotdog hotdog is offline
This just happened to me as well. Can someone forward me the information or instructionsmentioned above. Hotdog3476@yahoo.com
  #14
Old 08-22-2008, 11:24 AM
davidanderson davidanderson is offline
Quote:
ORIGINAL: Hayapower
Sent..
Hayapower, could you please send them to me as well? I have a 2005 Freestar and not only did the handle come off in my wifes hands, but the lifgate pistons are not keeping the lifgate up on there own anymore. I don't have the automatic lifgate, we have the manual one. The dealership told me that this would not be covered on our ESP premium warranty.
Thanks for any info you can send!
davidanderson.email@gmail.com
  #15
Old 08-22-2008, 04:11 PM
Hayapower Hayapower is online now
Sent..
__________________
05 F250 C/C FX4 6.0
1969 Firebird Trans Am
2003 Hayabusa GSXR1300
  #16
Old 08-25-2008, 03:24 PM
ppetey ppetey is offline
Same problem. I understand what I need to do (I think), but I cn't get the plate behind the license plate off.
Anyhelp will be greatly appreciated.
Thanks,
JM
__________________
JM
  #17
Old 10-03-2008, 08:55 PM
starrchilde starrchilde is offline
If it is not too much trouble, I am also interested in receiving the directions for reattaching this piece.
starrchilde @ insightbb.com
Thank you!
__________________
~ Starr
  #18
Old 10-07-2008, 03:49 PM
thefuse thefuse is offline
could i also bother you for the info. thanks
brene75@yahoo.ca
  #19
Old 01-15-2009, 12:09 PM
apkman apkman is offline
Same thing happened to us. Would you please send the info? Thanks so much! What a relief to know we won't have to take it in to get it fixed.
apkman@yahoo.com
  #20
Old 02-09-2009, 07:45 PM
ecwinch ecwinch is offline
Default Same here
Same problem here - please send info on fixing - eric@pateritech.com
With all these occurrences, you have to know this is a design defect.
Tags
2004, assembly, edge, ford, freestar, fuzzy136bellsouthnet, handle, latch, lift, liftgate, lock, opening, problem, rear, stuck
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
