Tranny won't shift?
Old Mar 12, 2008 | 06:44 PM
caseih1460's Avatar
Default Tranny won't shift?
Dear All,
I have a Ford Mustang, 1989, auto tranny that I recently pulled then put back in when I rebuilt the motor. All that was done to the tranny was new filterand fluid. Since then the tranny will not shift out of 2nd gear? Tachometer is also gone haywire and shows higher rpm than actual. Need some possible ideas as to what is wrong.
Thanks,
Caseih1460
Old Mar 15, 2008 | 12:49 AM
classiccruise's Avatar
Default RE: Tranny won't shift?
I'm not certain but it could be many things. I'd check:
Valve Body bolts loose/too tight
Sticking valves dirty/ports blocked
Missasembled oil filter
Misadjusted linkage to mnual valve
Mainline pressure
Governor valve
Valve body ckeck *****
Hope this help narrow things down
go300mph
Dec 31, 2010 10:08 PM
mws0019
Aug 7, 2009 01:18 AM
dmoore1965
Jul 4, 2009 06:19 PM
APS612
Apr 6, 2008 08:56 PM
jteam31
Nov 11, 2007 06:12 PM
