1955 T-Bird Automatic Trans Fluid
Old Mar 13, 2008 | 08:09 AM
gcsmial's Avatar
Default 1955 T-Bird Automatic Trans Fluid
the 1955 Ford T-Bird documentation says to use Type "A" transmission fluid which is no longer available. I am in the process of of restoring the car and I am looking for advise on what transmission fluid is compatible with the clutches and valves of this original transmission. What fluid is best? What will work?
Old Jan 4, 2009 | 12:53 AM
Default RE: 1955 T-Bird Automatic Trans Fluid
Type A may have been replaced by type "F". If you try any of that newer Dextron/Mercon crap you're likely to end up with headaches after a few miles.
Martin001
Dec 22, 2015 03:16 PM
GaryR
Jan 9, 2010 10:43 PM
royleexx
Jan 26, 2009 02:15 AM
teausant
Jan 16, 2009 09:24 AM
