CB radio install
Old Mar 16, 2008 | 03:16 PM
LPW's Avatar
LPW
Default CB radio install
Finding it hard to find a good place to mount my CB so I used a "saw" mount and it sits on the floor of my F250 (2006), with a bench seat. Can anyone tell me how to wire the power so Idon't get the RPM's from the alternator? Is there any way to reduce the noise?
Old Apr 2, 2008 | 10:40 PM
Sooner0233's Avatar
Default RE: CB radio install
In my 03 I wired mine to the accessory wires and have not had any issues with interference.
Old Apr 4, 2008 | 03:34 PM
93f250xlt4x4's Avatar
I installed myne underneath my dashboard in the center by my 4x4 shifter on my
93 f250. I wired it to my ignition and the only noise I get on it is my strobes but only if my squelch is down really low
Old May 5, 2008 | 10:35 AM
dpr's Avatar
dpr
You can run a coax type cable (RG-59) directly from the battery to the CB. Connet the sheild to the ground - negative and the center wire to the positive at the battery. On the other end at the CB only connect the positive for the powerand cut the sheild back a but and tape it off. You will need to ground the radio to the chassis. This should work to eliminate the engine whine. The bad part is it doesnt shut off when the rig is off so you you could accedentaly leave it on and drain the battery.
AJAtkinson
May 10, 2018 12:26 PM
boch1165
Mar 27, 2009 11:13 AM
b3n129
Sep 20, 2008 05:59 AM
LoSo
Jun 3, 2007 04:41 PM
Pike002
Aug 7, 2005 07:29 AM
