overhead console
Old Mar 20, 2008 | 03:38 PM
ford ex21's Avatar
Default overhead console
hello, i have a 2003 excursion with the v10. I have alittle probelm with the overhead console, it doesn't turn on. Has anyone had the same problem.
Old May 31, 2008 | 05:01 PM
elegance95's Avatar
Default RE: overhead console
My 04' Started doing this last week. I start touching the buttons and it turns on again.
Old Aug 17, 2008 | 01:01 PM
alightra's Avatar
I also have a 2003 v10 and mine did the same time about amonth ago. I replaced the fuse but no luck. Please let me know if you find a solution!!
Old Sep 3, 2008 | 11:50 AM
justjustin's Avatar
If your dimer is turned low, it may be hard or impossible to read with the lights on.
Also the dimmer could fail, do your other lights turn up and down?
Dumb, I know, but I thought I wasted a fuse or something once only to find one of the kids had
spun the dimmer down to zero.
The console can go bad, I have heard of it looking for info before.
Try googling it if you can't find it here, the site where people charge for answers had it discussed - maybe you?
Justin
Kennyhs
Sep 24, 2017 02:53 PM
donhut
Sep 16, 2007 04:44 PM
dmb5675
Aug 31, 2007 02:33 PM
dmb5675
Jul 16, 2007 03:27 PM
jbwilli
Dec 20, 2006 01:05 PM
