ABS Light
Old Jul 10, 2005 | 08:08 PM
gmm's Avatar
gmm
Default ABS Light
Have a 2003 Ford Explorer and the ABS light has come on. Brakes are OK and was wondering if a sensor could be bad or if this ABS light is a common light for different sensors on the suv. Thanks, for any help or knowledge on this problem.
Old Jul 12, 2005 | 05:15 PM
pakus's Avatar
Default RE: ABS Light
As a Ford Tech the most common reason for that on that year model is the rear speed sensor mounted in the rear differential. There is a new updated part to fix that.
Old Jul 12, 2005 | 05:44 PM
hockeyhitman69's Avatar
yes the sensor on the rear differential is probably the problem we have changed quite a few at the dealership i work at as well
Old Jul 12, 2005 | 06:03 PM
Most times you can get lucky. As the lil magnet will get a small piece of metal on it. an that will trip the lite , just clean it off an your good to go. I have found this quite often . An after yanking the diff apart to find no real problem. if it aint a big chunk on it an the diff aint making no noise . I let it ride. An other times I have found the wire chafed from folks 4- wheeling an shorting out the harness, and as the other post have started as well. but most times the lites comes on cause u got a problem of some type, I know the old RABS valve was foe ever failing
Old Jul 12, 2005 | 07:35 PM
gmm's Avatar
gmm
Thanks, for the replies on my problem, I will look at the sensor this week and change it out if needed. Thanks, Again
Bob Lobblaw
Apr 9, 2009 09:00 AM
Justin7666
Apr 11, 2008 02:04 PM
Hutch64
May 31, 2007 09:21 PM
