Suggestions for aftermarket rotors - stock/Ford parts suck
Old Mar 25, 2008 | 02:22 PM
jcasaccio's Avatar
Default Suggestions for aftermarket rotors - stock/Ford parts suck
Hi all -
Any suggestions for better than OEM rotors? I looked at FrozenRotors and they seem good. The stock rotors warp so easily and it's annoying - 35k on van and dealer has replaced rotors 3x under warranty. Next time I will do the brakes myself and want better parts. Any suggestions or experience with other rotors is appreciated.
Thx
Jack
Old Mar 26, 2008 | 06:34 AM
Default RE: Suggestions for aftermarket rotors - stock/Ford parts suck
What year Freestar? Which rotors?
Your problem may be with the calipers. I know the 2004 Freestars had an issue with the front calipers hanging up causing the brakes to overheat and warp the rotors. The rear calipers would hang up and cause excessive brake/rotor wear. I had the calipers, pads and rotors replaced 3 times under warranty on my 04 until they finally installed theupdated calipers. I'm looking at getting some drilled units and ceramic pads for a four corners this spring. Haven't chosen any MFGs yet.
Old Mar 26, 2008 | 10:22 AM
jcasaccio's Avatar
It's a 2006, and I will prob just do all 4 at the same time.
Old Mar 26, 2008 | 11:58 AM
tomb1269's Avatar
I have an 06 as well, live 15 miles from NYC. Wife is a brake dragger (ie I get 45-60k on non metallic she get 35-45K on the same type ofpads). I have just about 30K, of which 6k has been towing an 1800lb popup. I have not had any issues with the brakes and am on the original pads.
Old Mar 26, 2008 | 04:16 PM
Octane's Avatar
Ive always had good luck with Carquest rotors. Just make sure you get the good American-made ones, not the cheap Chinese ones.
EXPY2010
Aug 17, 2010 04:49 PM
NITROUSMIKEY
Jan 27, 2008 10:12 PM
whoyourdaddy49
Feb 11, 2007 07:45 PM
DCDave
Dec 1, 2006 11:11 PM
surferbum21
Jul 20, 2004 02:02 PM
