Green light on dash - "O/D Off"
Old Mar 25, 2008 | 06:16 PM
HRJewel's Avatar
Default Green light on dash - "O/D Off"
Any body have any experience with a green light on dash - "O/D Off"? It is on a 2003 Focus with 75000 miles.
Old Mar 25, 2008 | 06:19 PM
HRJewel's Avatar
Default RE: Green light on dash - "O/D Off"
Any body have any experience with a green light on dash that says "O/D Off?" It is on a 2003 Ford Focus with 75000 miles.
Old May 27, 2008 | 03:24 AM
fly47ely's Avatar
Isn't the O/D button on the left side of your gearshift?
Old Jun 2, 2008 | 12:09 AM
rjay29's Avatar
OK first off make sure you do not have it turned off,its the button on the left side gear shift, 2nd make sure your MAF sensor is not unplugged sometimes when you change the air filter it will become unplugged and this will cause the trans not to shift into O/D on the Focus,and last but not least the wires will sometimes break below the shifter shaft and to fix requires removing the console and fixing the wires
Old Jun 26, 2008 | 12:38 AM
robinson1212's Avatar
YES.. SAME PROBLEM. but mine is a little bit more complicated.
the o/d will switch on and off by itself. at some point it will flash the green light saying off.
and i can not get it to come back on. the button is un-responsive.
i also have some other problems but this is my main one.
Battery light comes on, batteries do not last... the battery cables on red side have melted in 2 different spots.
car will somtimes not start. what i have to end up doing to get car started is take a hammer, wrench, rachet, or plyers and tap the red battery cable then eventually it will start (normally)
"Key tumbler" in steering colum will not turn unless you hit it a couple times (3rd time replaced, i gave up)
This model has had several recalls but when i spoke to ford they said that MINE was not involved in recall.
BTW I can not afford to get another car i want to get these things FIXED. but i need to know how
Old Nov 7, 2009 | 07:12 PM
eroxannep's Avatar
Question green light on dash- o/d off
have 2005 focus and last night mine came on, trans fluid good went off for a min today. will it mess up anything to drive like that because o/d button isn't clearing it
muv
Mar 17, 2014 09:07 AM
Fishfool
Jul 15, 2008 07:26 PM
mtman1021
Oct 11, 2005 01:32 PM
