Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and let's talk about it.
stock slammin'
Old Jul 19, 2005 | 07:08 PM
junior's Avatar
Default stock slammin'
ok i have a task ahead of me and im not a ford guy at all but im gonna give it a shot the rewards are worth it.
im gonnna attempt to drop a 92 lincoln continental using all the stock components. i figure if i wire up the air release valves on the airshocks then i could hook them up to a switch with power and opent them when i want wich should drop the car and then hardwire the compressor so i can turn it on and off when i want to with a switch. i realize that the car is going to drop and raise slowly but im not worried about that. im gonna completely over-ride the ride control and make it all manual. sound easy enough but i have two days to get it done or the deal is off. i was wondering since your all ford guys im assuming, is there anything that im overlooking that i should pay more attention too or any problems im gonna run into wile doing this?? im not certifed but im a good mechanic and ive done harder things but because of the short time period i could use some help from people who might know more about the specifics of this car. thanks. if it works ill post some pick maybe even a link the some vid. any help would be greatly apriciated, im pretty sure it will go smoooth but thats when things go wrong. especially on fords\lincoln\mercury's.
NITROUSMIKEY
Jan 27, 2008 10:12 PM
sandytedder36
Nov 1, 2007 11:37 AM
gonzo
North East
Jun 6, 2005 12:09 PM
JTex
Feb 3, 2005 04:45 PM
oldschool1
Oct 9, 2004 12:18 AM
