ac stopped cooling
Old Jun 9, 2008 | 09:54 PM
darrell69's Avatar
Default ac stopped cooling
Hay everbody. 1999 escort sw ac stopped cooling on 2 different days then saturday stopped completely. Fuse is good, but no power to compressor,no visable problem with comp.r-134 is ok as far as I can tell without unit running.Can not find wiring diagram or ac gauge pressures. THANKS FOR THE REPLIES. PS I live in HOT Houston TX.
Old Jun 10, 2008 | 12:21 AM
Default RE: ac stopped cooling
Welcome to the site..
Check for voltage 'through' the A/C cycling/low pressure switch.. If the charge state is low,, either the comp will cycle rapidly, or not at all.. Check the high pressure cutoff switch as well after the cycling/low pressure connector.. Also possibly the WOT relay..
Old Jun 14, 2008 | 07:16 PM
darrell69's Avatar
Thanks for the reply. My chilton book does not give me much info on the a/c system. I think Ihave located the 2 switches, one on the line and one on the dryer. If this is correct what are the readings I am looking for? Thanks again.
michaelc10
Apr 30, 2024 03:17 PM
jenior71
Jul 23, 2007 07:52 PM
graven57
Jun 4, 2007 02:42 PM
tanklord
Apr 1, 2007 07:39 PM
95okexpolorer
May 27, 2005 11:41 PM
