Surge & dieneed help quick!
Old Jun 11, 2008 | 08:23 AM
thewheelman's Avatar
Default Surge & dieneed help quick!
My son & daughter in law just bought an 06 500 w/77k on the clocknice car, fleet car, looks and drives great except for the surge and die thing. When you start the car and go from park to drive or reverse it sometimes surges (big time) and then dies. The check engine light comes on and this time it's stayed on. We have about 20 days of warranty left from the used car dealer. Is this a common problem? A tsb issue? A recall issue?
Thanks in advance!
Hal
Old Jun 2, 2013 | 03:45 PM
gregwied's Avatar
I had a similar problem but my car would never turn off. Get the throttle body cleaned out that fixed the jumping my car was doing when I would put into gear. I don't know if the throttle body can get so clogged it makes the car die.
Old Jun 2, 2013 | 03:51 PM
Many times if anyone get into the vehicle before the warranty expires , it could void the warranty. Best if you took the vehicle back and have the selling dealer fix it.
Old Jun 4, 2013 | 08:12 PM
FordLifeSaver's Avatar
For that vehicle there should be an open recall to clean the throttle body on you're vehicle and reprogram the PCM. Call any local dealer and give them the VIN and ask if any recalls are are open.
Old Oct 27, 2013 | 06:02 PM
GearsNbeers's Avatar
My moms 500 has the same issue it seems for hers there is a recall to replace the throttle position sensor which is a common suspect for the rpm surge when shifting from park to reverse or netrual to reverse or drive. Her car also will sometimes surge forward when this happens she notice it wont do that when the ac is off. Just haven't had the time to take it into the dealer for them to replace it yet.
fastolds
Jun 8, 2016 04:38 PM
rockfangd
Jul 19, 2006 01:30 AM
chadr02
Apr 29, 2006 11:22 PM
Derrick
Apr 8, 2006 03:30 PM
