Engine running rough
Old May 26, 2004 | 10:08 PM
GiiDarwin's Avatar
Default Engine running rough
The engine in question is an 1982 F-100 5.9L I-6, rebuilt around 75,xxx miles ago. It has New plugs, new wires, new dizzy cap, rebuilt carb(good to specs that came with rebuild kit). A few weeks ago the truck had been sitting for a while, its a farm truck, when it was started it ran extremly rough, would die without gas, smoking a blueish smoke. New spark plugs were put in and no improvement was made, new wires were then put in and it ran alot better for a little while then become much worse again. The other parts were then replaced and i rebuilt the carb, and it began to run alot better,barely idles, but it still smokes a slightly bluish smoke and smells faintly of gas. So it appears unburnt gas is being expelled. A compression test showed all cyl around 125ish psi.
I would appreciate greatly anyones help in trying to diagnose this problem.
sorry for the long post
thanks in advance
-glenn
Old Aug 1, 2004 | 06:09 PM
e40water's Avatar
Default RE: Engine running rough
well I am thinking youre carb isnt set up properly, I am thinking youre choke needs to be adjusted, Check the timing as well, Maybe the fuel mixture is off too.
Good Luck
goatsauce
Apr 15, 2013 08:32 PM
ccsuhoops
Sep 4, 2011 11:06 AM
wick
Jun 29, 2008 04:12 PM
rrmojica
Dec 17, 2005 02:24 AM
bundy351
May 6, 2005 03:21 PM
