Transmission Woes
Old Aug 2, 2005 | 03:22 PM
savvy5473's Avatar
Default Transmission Woes
Hello,
I have a 1996 Ford Aerostar 3.0l. With a A4LD transmission. When driving the transmission shifts nicely from 1-2 but when accelerating the engine revs very high before a rough shift to 3rd. Then she shifts smoothly after that.
Any ideas??
Shane
Old Aug 2, 2005 | 04:55 PM
Default RE: Transmission Woes
Do you plan on doing the work yourself , or taking it to a shop ? , sounds like its going to die pretty quick, you could have a clutch pack -oring has failed, an finally it goes in gear after it builds up some pressure, Also its possible that the Gov. is sticking some,,An / or a faulty valve body. If it was mine I would drop the fluid an pull the valve body an take a look at it, How many miles dp you have on the car ?? , what does the tranny oil look like an smell ? is it a very brown an smell burnt an oil very thin dripping off the stick , ??? Or is a bright Red, very lil odor, an seems to cling to the stick ????
Old Sep 7, 2005 | 02:31 AM
Sabretooth's Avatar
you could also wipe the stick on a piece of nice white cloth...I use the back of my hand for convenience...and see if there are metal shavings in w/ the fluid...it'll look kinda like the lead of a pencil all crushed up...you could need a change of oil and filter for the tranny...just my opinion, it may help w/ the shifting...did for mine
SteveHenderson
Dec 15, 2011 03:40 PM
sannis
Dec 22, 2007 11:25 AM
raggy742000
Oct 23, 2007 08:59 AM
mattymax
Mar 2, 2006 12:46 AM
KSA
Nov 11, 2005 02:08 AM
