'97 Aspire Windshield Washer
Old Sep 23, 2008 | 09:19 AM
articoli1's Avatar
Default '97 Aspire Windshield Washer
I turned on the washers yesterday and nothing. The wipers started working, but not the washers. The reservoir is full. Has anyone had a similar problem?
Old Sep 23, 2008 | 11:00 AM
Default RE: '97 Aspire Windshield Washer
Do you hear the reservoir pump run at all with washer selected??
If not,, chances are it's the reservoir pump failed, possibly the multi function switch but the small pump motor has a higher failure rate,, more so if straight water and not windshield washer solvent had been used.. If you can access or trace the loom from/down to the rerservoir in the LH fender check to see if there is 12v on the BL/O wire when the pump is selected ON.. If there's 12v there the pump is bad....
Old Jan 11, 2009 | 01:06 AM
Another thing to remember is (like a radiator) never to leave just water in the reservoir over winter seasons if the temperature in your area ever drops below 40 degrees. Pump parts can be damaged at this temperature.
pmckinney
Dec 13, 2006 02:26 AM
pmckinney
Dec 7, 2006 03:10 PM
vksan
Nov 5, 2006 02:24 AM
daveranger
Aug 14, 2006 02:20 AM
lat1967
Jan 3, 2006 12:44 AM
