Any idea where I can find a hub bearing puller?
Old Sep 25, 2008 | 03:49 PM
Zumkopf's Avatar
Default Any idea where I can find a hub bearing puller?
The manual says you need a front wheel hub remover (P/N 204-069) to remove the frunt hub bearings (sealed unit). However, none of the local parts shops have them to lend. I tried making one out of steel stock and some hardened bolts, but it only bent the steel. I think I need the real thing. Any ideas where I can get one? (I already bought the replacement hub unit, and already got off the axle nut (that was a bear) and the three bolts holding it from the inside (also a bear), so I hate to give up now.)
Old Nov 16, 2008 | 06:41 PM
techford's Avatar
Default RE: Any idea where I can find a hub bearing puller?
Hi, you don't really that special tool. There is two ways to do that I use. 1- Using a big hammer, you knock against the hub, with the wheel fully turn, from the inside to the outside, from the back and front of the hub so that the unit comes out evenly. 2- If you have an air compressor and an air hammer, using the chisel tip, you go between the hub and the knuckle. Or using the hammer tip, directly against the hub for the rotor.
Nic.
makuloco2000
Feb 23, 2014 10:12 AM
makuloco2000
Sep 19, 2013 11:12 PM
O2THPIC
Jun 11, 2009 10:10 AM
barnall
Apr 28, 2009 10:19 PM
sprdty21921
Aug 28, 2005 04:15 AM
