Go Back   Ford Forum - Enthusiast Forums for Ford Owners > Ford Trucks, Ford Vans & Ford SUV's > Ford F-250 & Ford F-350
Welcome to Ford Forum!
Welcome to Ford Forum,
  #11
Old 10-30-2008, 07:04 PM
THEGOOSE THEGOOSE is offline
Default RE: 99 f250 7.3 knocking hard to start!
i have a snapon scaner in my hand right now and its telling me codes- 231 - 340 - 470 - 1294 - 1316 and it says myinjector pressure is 2300 psi at crank. THE RPM AT CRANK WAS 100 TO 120. what can i retrevie from the scanner that would help figuar this out.
THANKS: GOOSE
__________________
1999 f250 superduty, 7.3 diesel, auto, 2 wheel drive, 293,000 miles,
  #12
Old 11-02-2008, 12:30 PM
REFERENCE Voltage is 5.03V[/align][/align]i bought a fuel pressure tester and i checked the fuel pressure at the pump on the frame rail.[/align]key on 65psi[/align]cranking 64/66 psi[/align]the book says it should be 45/55 could this pumpbe the problem?[/align]i havent checked the pressure at the head yet, im a little afraid the line is rusty looking. i hope it dont break!
THANKS: GOOSE[/align]
__________________
  #13
Old 11-28-2008, 06:02 PM
stang8895 stang8895 is offline
I have a 95 f-250 7.3L. This sounds like a problem thatI have had, white smoke all of a sudden misfire, no power eventualy didnt start. I found through diagnosing the oil level was low causing not enough oil presure to operate injectors. The problem was the injector o-rings went bad causing the engine to burn the oil and lowerd the oil level and starved the highpressureoilpump. I replaced the o-rings and it ran fine. hope Im not too late.
  #14
Old 02-01-2009, 11:55 PM
Unhappy well i still havent fixed the truck...
i had to set the truck aside for a few months but i am getting ready to start checking the injectors this week.
as far as the last post by stang8895 i have checed the oil pressure pump and it looks fine. but thank you very much for the reply!
THANKS ALOT GUYS!
THE GOOSE
__________________
  #15
Old 02-02-2009, 06:53 AM
HorchataKing HorchataKing is offline
I had this same problem on a 95. Changed my cps and it would start easy on a warm day but cold starts were still an issue. I found out that it was my glow plugs were dead and it was too cold to start without cranking for several minutes. If you have a block warmer on the truck you can use that to facilitate starting. 15 minutes is plenty for me. If not replace your glow plugs and cps and try to start it. The glow plugs are a huge amount cheaper than injectors (just did mine).
  #16
Old 02-02-2009, 01:24 PM
I HAVE PLUGGED THE BLOCK HEATER IN AND THAT WILL MAKE IT START BUT IT WILL BARLEY RUN AND IT BLOWS WHITE SMOKE THAT REEKS OF DIESEL FUEL.
THINGS I HAVE DONE TO TRY AND FIX THE TRUCK:
1. CHANGED THE CAM SENSOR
2. CLANED WHERE THE FUEL FILTER SITS
3. NEW FUEL FILTER
4. NEW AIR FILTER
5. CHANGED OIL
6. CHECKED THE OIL IN THE HIGH PRESSURE FUEL PUMP
7. I DID A VISUAL CHECK OF WIRES, CONECTORS AND FUSES
8. CHECKED FRAME RAIL FUEL PUMP
9. DID A METER CHECK OF THE GLOW PLUG RELAYS [BUT STILL IM UNDESIDED ABOUT THE RELAYS]
10. USED A SCANNING TOOL TO GET CODES 231 - 340 - 470 - 1294 - 1316 and it says myinjector pressure is 2300 psi at crank & THE RPM AT CRANK WAS 100 TO 120.
THANKS FOR THE HELP!
__________________
  #17
Old 02-13-2009, 11:19 PM
Talking It's alive!
I had a ford diesel tech fix my truck.
1. 6 bad glow plugs
2. Bad glow plug controler
3. Wire harness to drivers side injectors was broke and unpluged.
4. Valve cover gasket
$600 bucks and my baby is up and running again!!!!!!!!!
Thanks everybody for your help!!!!!!!!
Thanks: Goose
__________________
  #18
Old 02-26-2009, 06:01 PM
BigRig Mechanic BigRig Mechanic is offline
Default 99 f250 7.3l DIT problems
hey guys hows it going
im a diesel mechanic, i ve worked on anything and everything , just no one seems to have the right answers about my problem and the dealer aint worth there two cents,lol
im wondering if u can assit me wit a problem with my 99 f250 7.3l dit 150,000mi
ive had rough running problems for a few weeks then it ran fine, then about 4 days ago its started spiting and running rough then stalled, could not get to fire unless it sat for about 20min, and it would only run rough and no power
went to dealer and put new cps sensor in it, (it was under recall) still wouldnt start so we hooked up the computer and started cheching systems and elimanating thing, i found a broken harness at my right side valve cover and replaced in, cleared all the codes and it fired right up ran awsome, and as i pulled out onto the street it stalled, i got it runnung again but it was rough, we rescanned it and got codes for #1 and #2 injectors not connected, i could move the truck but at very little power, so i had it towed home and started checking the pcm,imd and all sensor wiring and plugs, ive done all the resistance and voltage test between the idm and pcm circuits,
i have a few idm codes about a year ago, the engine light woul come on and the truck would have reduced power, id pull over and clear the codes and the truck would run fine then it happened about 5 months later while off roading i was in first gear crawling over rocks and stuff at high rpm and the code can back a few time, took about 4 times to clear it 4 good and its been good till about a few weeks ago
at the dealer we checked all the hpop pressures and % as well as the ipr system all are good
i can start it about everyfew hours it runs rough and will only stay running about 2-3minutes and stalls,
im pretty sure its the injector driver module, but as they r pricy i thought id see if u guys have any ideas,
thx for the help, and if i can hepl u with anything dont be afarid to ask
thx matt
london ontario canada
  #19
Old 11-01-2009, 07:42 PM
crazy4wdracer crazy4wdracer is offline
I am having the same problem as "THEGOOSE" on my 1997 F250 Powerstroke with 275K. I think my injector O-Rings could be bad. My truck started to knock and lose power today and I had to get it towed home. This thread helped me out though, glad I found it.
Tags
73, 73l, 99, cam, diagnostic, diesel, ford, hard, rough, ruff, running, runs, sensor, start, truck
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
