1995 Ford Taurus Single Cam 3.0 – Stalls/quits running
Old Nov 30, 2008 | 07:54 PM
mjupman's Avatar
Default 1995 Ford Taurus Single Cam 3.0 – Stalls/quits running
1995 Ford Taurus Single Cam 3.0 – Stalls/quits running.
Starts and runs just great for 145k car. Running down the road or @ a stop light etc. the car just shuts off like someone turning off the ignition key. All indicator lights in the dash come on then shut off and engine quits. Happens ONLY @ normal operating temps. Cold cycle is fine. It is not time dependent. It does not happen @ the same “warm up temp” every time but does happen EVERY time the car is driven. I have not check for any codes. (It is ODB 1). No check engine light remains lit before/after the incident. Engine does crank over during the no-start/re-start period but, fails to start. Can NOT re-start car until it cools off for 20 or more minutes. After that, it starts right back up on first turn of the key and is drivable until engine temp builds and @ some point it will stall out.
In the NO-START MODE = I hear the fuel pump come on & pressurize when attempting to re-start and have check for fuel @ the test port on the fuel rail. I have not done a fuel pressure test. I have verified spark @ ONE spark plug but, because of the nature of WHEN the problem occurs, along side of the road, trouble shooting is difficult. Also, there is relay of some shorts under the flat plastic fan shroud that has all the warnings and engine info/decals on it, above the two cooling fans,, that vibrates severally for a few short seconds after releasing the ignition switch back to the “run” position from the attempting to starting position, then it stops.
Parts replaced so far that others have recommended from similar cases as this one are:
Ø Ignition coil, thinking this is in the hot spot/center of the engine. No change>still stalls out
Ø Exact case description from same year/engine was to replace the Distributor Control Module mounted on the outside of the distributor. No change>still stalls out.
Ø All tune up items replaced @ 106k, plugs, wires, Dist. Cap, Fuel filter (last week>opened old one up and checked>clean).
Old Dec 11, 2008 | 06:27 AM
krugerblue's Avatar
Default RE: 1995 Ford Taurus Single Cam 3.0 – Stalls/quits running
I have exactly the same problem with my Scorpio MK1 (or Granada Scorpio as it is also called) and this is really getting on my nerves. I changed all the filers, the IACV, the TPS, bt my car shows exatcly the same simptoms as yours. IN addition, my engine also stalls when I corner and the engine is idling.
I was thinking that the fuel pump may be faulty.
Old Jul 9, 2010 | 05:07 PM
sashafirst's Avatar
what you did to fix it?
enelya
Jul 29, 2012 07:37 PM
k87fordf150k
Sep 23, 2010 12:56 PM
CoreyTrevor
Oct 27, 2009 12:54 PM
96F350Panel
Nov 27, 2007 02:59 PM
Aussie Explorer 98
Nov 13, 2005 02:19 PM
