1993 Taurus
Old Aug 18, 2005 | 03:21 AM
NAVY's Avatar
Default 1993 Taurus
[:'(]93 Taurus - no signal lites, Nr 1 fuse 15 amp was blown while driving/indicating a left turn, replaced main fuse, brake lites, flashers, hi mount lite, speed ctl all work, still no signals, 286 000 km . any suggestions. tks [:@]
Old Aug 18, 2005 | 01:25 PM
Default RE: 1993 Taurus
Try this site out:
http://www.autozone.com/servlet/UiBr...3d800d3088.jsp
fig. 14 and 33 are the same one for '88 the other for '92, so a '93 maybe the same.
Anyway if fuse 1 blow it was cause by a high current or short in the wiring, switch, connector, or bulb. My guess is that the multi-switch in the fig. is the turn switch. If all other lights are working then switch must be bad, that is if your brake lights work with the padle. The schamatic is not right, forget about the lights to the left center and think about the brake switch going though the muti-switch how else could the rear lights at the bottom work with the brake switch? but check for a flasher working though another fuse. I'll see if I can find if that it the case.
Old Aug 18, 2005 | 01:33 PM
Okay so if fuse 5 is good and emergancy lights work then electronic flasher is working and I believe so sould the turn signal though the same elec. flasher.
sundani
Apr 16, 2007 01:47 PM
davidsca
Jun 25, 2006 01:36 PM
PhilRe3
Apr 26, 2006 11:59 PM
jeff1784
Jan 28, 2006 04:05 PM
discusgary
Nov 28, 2005 12:59 PM
