AC Compressor Coil
Old Jan 9, 2009 | 11:47 AM
dosnotches's Avatar
Default AC Compressor Coil
I have the Compressor free, but I cannot get it out of the car. I've tried the wheel well, removed upper and lower rad pipes, water inlet pipe, etc. I have the clutch and pulley off of the compressor, but the magnetic coil is not coming off easy (especially since I can't free it from the car). I was planning on replacing the coil, pulley and clutch. Is there an easy way to get the coil off (while it is still in the car) or is there a way to test if the existing coil is still OK? Thanks!
Old Jan 9, 2009 | 09:37 PM
Sterling_Six's Avatar
Default RE: AC Compressor Coil
ORIGINAL: dosnotches
Hello and good day to you:
Just a couple of questions first:
1 What is the YEAR....MAKE...MODEL...ENGINE SIZE....Of this Vehicle???
I'm sorry but we can't help if we don't have the Basics.
Old Jan 10, 2009 | 09:35 AM
dosnotches's Avatar
Sorry. It's a 1999 Taurus w/ DOHC V6.
Old Jan 10, 2009 | 05:58 PM
Thank you:
I only had to pull the Compressor Unit on my 2000 Taurus Sel one time... The Gentleman you need to PM is Way2old he is quite knowledgeable in this than me.
I will tell you how I did it tho...if that will help?
Remove the Drive Belt.
Remove the right hand cooling fan.
disconnect the power steering hose from the pump and remove the nut securing the hose to the Front exhaust manifold.
Remove the refrigerant manifold and the tubing from the rear of the compressor
Disconnect the electrical connectors at the compressor clutch and at the pressure cutoff switch.
disengage the wiring harness from the compressor bracket and move th harness aside
Remove the compressor mounting Bolts(Note on top left hand mounting bolt must come out with the compressor
remove the compressor from its bracket.
Left it up from the front of the engine.
Hope this helps...if not please advise...
Old Jan 10, 2009 | 08:01 PM
way2old's Avatar
Is this the 4 valve engine or the 2 valve? 4 valve is way more complicated. I think it has to come out from under the vehicle. Here is instructions for 4 valve. Six is real close on the 2 valve engine. Good luck. If just the clutch coil is all that is stopping you, there is a snap ring that holds it in place. Then it will come off. If it is a Sanden compressor. If it is what is called the FS 10, it needs a puller to remove it. Without seeing the compressor and having numbers from it, I can not tell you which one you have.
3.0L (4V) Engine
Removal
[ol][*]
Recover the refrigerant.[*]Drain the engine coolant.[*]Remove both cooling fans.[*]Remove the drive belt from the A/C compressor pulley.
Raise the vehicle.
A/C Compressor Removal—3.0L (4V)
[/ol][*]
Disconnect the compressor manifold and tube at the condenser core. Discard the O-ring seal.
[ol][/ol][*]
Detach and disconnect the heated oxygen sensor electrical connector.
[ol][/ol][*]
Disconnect the pressure cutoff switch electrical connector.
[ol][/ol][*]
Lower the vehicle.
[ol][/ol][*]
Remove the water pump hose and tube assembly.
[ol][/ol][*]
Remove the water bypass tube.
[ol][/ol][*]
Detach the wiring harness from the compressor manifold and tube assembly.
[ol][/ol][*]
Disconnect the compressor manifold and tube assembly from the A/C compressor. Discard the O-ring seals.
[ol][/ol][*]
Disconnect the compressor manifold and tube assembly suction hose spring lock coupling. Discard the O-ring seals.
[ol][/ol][*]
Disconnect the A/C clutch field coil electrical connector.
[ol][/ol][*]
Remove the four bolts and the A/C compressor
[ol][/ol]
Old Jan 10, 2009 | 09:31 PM
Hello to you Way2old:
Those Links you have provided are not going thru...It gives a Error Page....
Sorry....
Old Jan 11, 2009 | 11:16 AM
way2old's Avatar
The links will not post. I just copied it from manual. Is that better Six?
Old Jan 11, 2009 | 06:52 PM
ORIGINAL: way2old
[sm=oopssign.gif] LOL sorry....I should have Know that was the case...LOL
Thanks anyway
Old Jan 12, 2009 | 11:43 AM
dosnotches's Avatar
Thanks for the help. I got the compressor out. I had to remove both radiator fans and take it up closer to the driver side. In the process I removed a hard metal pipe that feeds into the water pump from the bottom. The part was very corroded and I really need to replace anyway. Does anybody happen to know what this part is called or have a part number handy, etc? Thanks!
Japoipnoi
Jan 20, 2012 08:08 PM
rlevy64614
Jun 8, 2007 08:55 PM
hrybls
Oct 8, 2005 01:41 PM
mnoker1
Oct 5, 2005 11:07 PM
dadstaxi
May 5, 2005 04:11 AM
