Sport Trac anti spin differential questions
Old Jan 15, 2009 | 08:07 AM
Armytruck's Avatar
Default Sport Trac anti spin differential questions
Would any happen to know if a anti spin differential was put into the Sport Tracs? If so would the VIN No. indicate it? If not, best way to identify it? If Ford did have a optional limited slip would anyone know if this unit could be swapped with another ford unit? Reason for the last question I have a 98 Splash 4x4 that the stock axle went out of and put a limited slip into it from a mustang which supposedly had the same axle. It did wonders in getting around without even putting the truck into 4x4 off road.
Old Jan 15, 2009 | 12:00 PM
Default RE: Sport Trac anti spin differential questions
Limited slip was an option for the Sport Trac.. What year do you have? You can identify the axle options by the VCL (vehicle certification label) in the drivers door jamb.. Where it says 'axle' there should be a 'D' code 2~4 for the limited slips/ratios.. It will/should also have the rear diff tagged with the identifier info..
explorerman
May 10, 2016 11:56 AM
rod525
Oct 25, 2014 05:47 AM
Towguy76
May 22, 2013 12:01 PM
amped4life
Jul 24, 2010 11:38 AM
amped4life
Jul 24, 2010 11:35 AM
