2003 crown vic headlights turn off
Old Feb 3, 2009 | 03:38 AM
gnilier's Avatar
Default 2003 crown vic headlights turn off
My 2003 crown victoria headlights turn off at night, in auto and and hard on, they cannot be turned back on, but will turn on by them selselves. Ford has replaced the on off switch and the multi-function switch. Anybody got any ideas. HELP.
Old Jun 16, 2010 | 09:46 AM
corky777's Avatar
I recently had this problem fixed. It is your LCM(lighting control module) located under the dash above your right foot. You can hear it click when you lights turn on/off. The dealer wants $562.00 to replace and $200.00 removal & reinstall. Very easy to remove yourself. Two or three scews and three harnesses. It can be rebuilt, I had mine rebuilt for a $100.
Old Jul 16, 2010 | 12:14 AM
chiefjack's Avatar
I am having the same problem. Diagnosed as the multi function switch. When I shake the switch, the lights come back on.
Should be replacing the switch tomorrow.
Old Oct 24, 2011 | 08:07 PM
chiefjack's Avatar
Found this info while searching for more help. Replacing the multi-function switch did not fix it.
LCM WOES gone for now. External Relay fix - Crownvic.net
05 Headlight issues - Crownvic.net
David Oliva
Sep 26, 2023 09:22 AM
patrickcharles
Nov 10, 2008 09:01 PM
tedhontz
Sep 17, 2008 11:57 PM
archangel95
Aug 16, 2008 10:42 AM
auctioneer
Oct 19, 2005 10:25 PM
