1986 ford f150
Old Mar 24, 2009 | 10:00 PM
vmx555's Avatar
Default 1986 ford f150
it idles good but when you give it gas it dies (new plugs,fuel filter,plug wires) need help
Old Mar 25, 2009 | 06:16 PM
way2old's Avatar
Check the Throttle Position Sensor. Sounds like that may be the problem.
Old Mar 26, 2009 | 05:37 PM
vmx555's Avatar
well replaced that still doing the same
Old Mar 27, 2009 | 08:44 AM
Bullitt94's Avatar
Does your cap and rotor look good?
Would your timing be off for any reason?
Vacuum leak somewhere?
Old Mar 29, 2009 | 09:36 AM
vmx555's Avatar
i found out my erg valve was plunged order a new one hope this fixes it replaced map sensor if not thinking its my fuel pump its making a noise
Old Apr 16, 2009 | 03:48 PM
vmx555's Avatar
got a code reader here are the codes i got need help
pip circuit failure
evap control system below minimum voltage
tps circuit fault,below minimum voltage
primary fuel pump circuit failure
thks in advance
thekid_jesse
May 27, 2021 04:19 AM
shadow11
May 5, 2008 01:24 PM
spf150
Mar 22, 2008 10:24 PM
Ford Master
Feb 3, 2008 08:21 AM
ck_russell
Oct 11, 2006 12:13 AM
