OD Light flicker on and Off:
Old Jun 29, 2004 | 02:31 PM
97 EddieB's Avatar
Default OD Light flicker on and Off:
This does not effect the Overdrive, it is ann[:@]oying.
I do not know if the OD is off/On.
If I touch the selector tree Up/Down/In/Out, light will go off, but come back on because of vibration..
Help Please!![]
Old Jun 9, 2005 | 02:27 AM
EB99's Avatar
Default RE: OD Light flicker on and Off:
If your OD Off light is flickering you might want to have a diagnostic ran. The Off light is like the check engine light for the transmission. I learned this the hard way. Just this last weekend mine started flashing it wouldn't go into 4th ,and when I pulled over it dumped the tranny fluid. I took it to the shop and the diagnostic said the Torque converter was failing. Now it needs to be changed at 65K [:@]!!
Eric500
Nov 2, 2012 11:31 AM
oceanblue_2001
Feb 27, 2010 05:16 PM
4Duh
Sep 6, 2007 06:59 AM
5literjay
Oct 15, 2005 02:10 PM
