rough idle
Old Aug 31, 2005 | 08:39 PM
wheelerlt's Avatar
Default rough idle
I've got a 2000 Ford Focus LX - non Zetec engine with 69300 miles. The engine will sputter every once in a while when at idle, and only after being warmed up. I've replaced the plugs, plug wires, fuel filter, O2 sensor, pcv valve, and I never buy the cheap gas (chevron or shell only), and i've even used a couple of bottles of the Valvoline fuel injector cleaner. My check engine light has never come on, but the sputters are so bad, that you would think the engine is going to stall, but it catches itself everytime.
Any ideas?
Old Nov 14, 2005 | 09:48 PM
acheofmypain's Avatar
Default RE: rough idle
Sometimes the RPM's are set to high and can give you a rough idle
Old Nov 15, 2005 | 01:32 PM
wheelerlt's Avatar
Thanks for replying. Actually, it was dirty injectors. Got them cleaned, and the engine works like new again.
Old Nov 15, 2005 | 09:40 PM
Glad to be of help.[sm=smiley20.gif]
goatsauce
Apr 15, 2013 08:32 PM
93redxlt
Mar 18, 2010 04:44 PM
Olpapa
May 18, 2008 03:22 PM
gearyoil
Nov 1, 2005 07:02 PM
cajahorse
Oct 30, 2005 10:17 AM
