E-350 Drum help needed
Old Sep 4, 2005 | 08:11 PM
coater's Avatar
Default E-350 Drum help needed
Hi. My 83 E-350 needs new shoes and I've got them and am ready to go. BUT, the passenger side drum seems to be stuck on. I don't see anything structurally different from the driver side drum, so maybe it's just being a pain in the neck?
Anyone know why the drum won't pull right off like the driver side drum did?
THANKS!!!
Old Sep 5, 2005 | 04:17 AM
Default RE: E-350 Drum help needed
1st , did you try backing off the brakes , 2nd , you sure the park brake aint set, 3rd Get a BFH an try whaling on it , Sometimes they get stuck to the hubs (rusted up ), Also they make a special tool just for doing that , Ive never had to use one , But I know some folks insist on having the rite tools to do the job, An finally on the really stubbron ones you take a torch thru the brake adj. slot an SMOKE IT !!!!!
Old Sep 5, 2005 | 04:40 AM
coater's Avatar
Ramrod48, I'm with you. Got it. you reassured me that all I needed to do was some good ol bashin. I'll get on it.
Ram Rod... that's great. I once met a woman whose father starred in Vice Squad as Ram Rod. Wings Hauser was the star.
Thanks, my good man.
You and Wings.
-Mike
Old Sep 5, 2005 | 04:46 AM
you can also spray a little pentrate oil around the stud holes an the hub flange , before you break outthe hammer ,, Oh gotta warn you , you might get some dust flying an wear safety glases too , you can get sparks off the hammer , an sometimes as wee bit of steel flying off , so be careful,
Old Sep 5, 2005 | 05:15 AM
coater's Avatar
I agree. the liquid wrench is doing its job right now.
then... hammer on and testing the balance and strength of the hydraulic jack.
Old Jun 11, 2019 | 07:35 PM
BeemerNut's Avatar
Penetrating oil and some heat (not a lot) then lightly hammer around each stud and edge of drum in the outward direction. Not beating hard and damaging the wheel bearings.
Clean off all mating surfaces including the concentric lip of the hub as well the opening on the drum. Add a little anti seize compound,
a very light coating to all contact areas especially the concentric hub lip and drum center bore. Open wheels without wheel covers driving in the rain or pressure washing accelerates your stuck and rusting conditions. Anti seize for easy removal next time......~~=o&o>......
zeeborg
Nov 19, 2021 02:47 AM
tgresssky
11
Jul 25, 2016 06:26 AM
harley3348
Nov 4, 2014 01:36 PM
mschwennes
Mar 7, 2007 07:14 PM
peterjcb
Jan 24, 2005 08:01 PM
