Fuel Pump
Old May 18, 2009 | 12:31 PM
APS612's Avatar
Default Fuel Pump
2001 Expedition: is the fuel pump located in the fuel tank? If so, is the only way to change it by dropping the tank? Thanks
Old May 19, 2009 | 11:10 AM
APS612's Avatar
Default Fyi
Well the fuel tank is mounted under the drivers side inside the frame rail just in front of the real axle. There is a space just above where the fuel pump is located and I am not yet 100% sure if the fuel pump can be pulled out without lower the tank. I have raised the body a few inches and have the ring holding the unit in place loose so far. I will repost more information when I find out this evening just in case anyone else should run into this same issue.
Old May 20, 2009 | 10:34 AM
APS612's Avatar
Default Fyi
Well yes the tank needs to be dropped. There are 3 straps to be released. Drop down the rear end of the tank with a floor jack or something and you can remove the pump. This should qualify to be on the "Dirty Jobs" show.
Old May 20, 2009 | 01:52 PM
Wink
If your lucky enough, the tank hadn't been just filled either
jozepy24
Jul 13, 2019 05:21 AM
fordexpedition2006
Apr 21, 2017 05:23 PM
Spaznaut
May 24, 2014 02:10 PM
ballaholic29414
Nov 12, 2010 06:04 PM
grumpydave
Jan 18, 2008 03:15 PM
